Improving Visio Load Speed
Solved632 views23rd October 2025performance Visio
David Rid [DevOps Enabler]957 22nd October 2025 0 Comments
Hello everyone,
I’ve created a relatively large multi-view screen in Visio that contains 144 links to images. When I open the Visio page, it takes quite a while to load (~25 sec), which is expected.
However, when I switch between Visio pages within the same DataMiner tab, the main page (with the 144 images) reloads every time new. This makes navigation very slow.
Is there a way to make Visio keep the main page cached or loaded in the background, so that switching between the visio pages is smoother once the Visio representation has started?
Any ideas, tips, or suggestions would be greatly appreciated!
Thank you for your time and help.
Best regards,
David Rid [DevOps Enabler] Selected answer as best 23rd October 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 23rd October 2025 1 Comment
Hi David,
You can stop browsers (created when a Link shape’s data starts with a hash) from unloading and reloading between page switches by setting DisposeWebBrowserWhenNotSelectedPage = false. Make sure to apply this to every shape (you can select them all and add it in one go).
Options      DisposeWebBrowserWhenNotSelectedPage=false
David Rid [DevOps Enabler] Posted new comment 23rd October 2025
David Rid [DevOps Enabler] commented 23rd October 2025
Awesome, exactly what I was looking for! Really appreciate your help.
