Impact of increasing Element Log level in smart serial connections
Solved1.43K views4th March 2021
Fenta Alemahu [SLC] [DevOps Advocate]1.32K 15th February 2021 0 Comments
Hi all,
What is the impact of increasing the Element Log level (say to level 4) in a smart serial connection?
In my case, when I increase the log level (to 3 or 4), the element goes into timeout and want to know the root cause for this.
Fenta Alemahu [SLC] [DevOps Advocate] Selected answer as best 4th March 2021
Thijs Vanovenacker [SLC] [DevOps Advocate]2.54K Posted 15th February 2021 0 Comments
Hi Fenta,
The log level that you configure in system center should not have a direct impact on the timeout state of your element.  With the log levels you define how much (/deep) you want to view the log information on that element. Please see the help for more on this topic: Element logging.
In order to figure out what is causing the timeout, you could start with opening the streamviewer. There you might already spot what is causing the communication issue resulting your element to go into timeout state.
Please let us know if you need further assistance. Good luck!
