IAS TextBox PlaceHolder
Solved1.09K views11th February 2025Automation DIS IAS interactive automation script
David Rid [DevOps Enabler]957 7th October 2024 0 Comments
I'm working on the widgets for an interactive automation script.
I added a TextBox to the widget and set its placeholder property, but no gray placeholder text is appearing in the UI. Am I missing something, is there something else I need to do?
I'm using the 7.0.5 Version of Skyline.DataMiner.Utils.InteractiveAutomationScript because of the DataminerVersion (10.4.0) I am working on.
David Rid [DevOps Enabler] Edited question 11th February 2025
Ive Herreman [SLC] [DevOps Enabler]14.52K Posted 7th October 2024 0 Comments
Hi David,
Your code snippet looks correct.
After running more tests, I can confirm that I see the same behavior on the latest 10.4.10 dataminer release.
In the dataminer cube, the placeholder is not visible, however, running the same interactive automation script in the web framework (through a low code app), the placeholder value does appear.
I'm unsure if this is a bug or a limitation in cube.
In any case, if you need this, I suggest to reach out to Skyline Techsupport.
David Rid [DevOps Enabler] Selected answer as best 7th October 2024
