How to use the class library in the automation script C# code
Solved1.63K views12th July 2023automation engine Automation script class library
Miao Miao366 13th October 2022 0 Comments
Hi
I am trying to use the clasespace. Seems it need assembly reference? Where could i find the .dll file for this? and how could i import the .dll file?
In my automation script C# code I use then i got following error in the C# action codes:
using Skyline.DataMiner.Library.Common;
using Skyline.DataMiner.Library.Automation;
Thank you very much.
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 13th October 2022 3 Comments
To be able to use the Class Library, you'll need to do the development with Visual Studio and DIS.
Developing DataMiner protocols and Automation scripts as Visual Studio solutions | DataMiner Docs
With the correct settings enabled (DIS settings | DataMiner Docs), DIS will generate the necessary QAction (Protocol) or Exe (Automation) with the code that is being used.
There is also a course regarding DIS that you could watch: DataMiner Integration Studio - DataMiner Dojo
Introduction to Class Library: Class library introduction | DataMiner Docs
Miao Miao commented 13th October 2022
Thanks Michiel.
I do have DIS but my DIS could not connect to the dataminer server for some reason. Can I still use DIS offline to generate the correct necessary QAcition and Exe with code to use Class Library?
Any example codes i can find?
Thanks
Michiel Oda [SLC] [DevOps Advocate] commented 13th October 2022
Hi Miao
Here you can find the introduction to Class Library with also some examples:
https://docs.dataminer.services/develop/devguide/ClassLibrary/ClassLibraryIntroduction.html
DIS does not require a DataMiner connection to be usable.
