how to use Alarm console “severity duration” column
Solved2.00K views9th July 2021
HyungMo Jung20 9th July 2021 0 Comments
When creating an Alarm tab page in the alarm console, use Filter to create a tab page.
If you try to add Severity durations with the Add column function, the Severity durations column does not exist.
I would like to ask if the "Severity duration" column is not available when using Filter.
Toon Casteele [SLC] [DevOps Enabler] Answered question 9th July 2021
Michaël Pincket [SLC] [DevOps Advocate]2.09K Posted 9th July 2021 0 Comments
Hi HyungMo,
It is not possible to add the "Severity duration" column on a history tabpage with a filter. The reason for this is that we can not calculate the severity duration correctly as it could be that some alarms are filtered out which are needed to calculate the severity duration.
HyungMo Jung Selected answer as best 9th July 2021
