how to use Alarm console options – “keep active alarms”
Solved1.80K views18th July 2023
HyungMo Jung20 15th July 2021 0 Comments
Please advise the function of “Keep active alarms” in Options Tab.
We can’t find any difference whether we check or uncheck this option.
Simon Raine [SLC] [DevOps Member]2.08K Posted 15th July 2021 0 Comments
If the alarms are active alarms they will remain in the sliding window (last hour in your case) even if they do not fall within that window.
More information can be found in the help on this topic
