How to turn a suggestion event into an alarm using a correlation rule?
Solved3.83K views15th September 2021augmented operations Correlation
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 14th September 2021 0 Comments
DataMiner supports suggestion events, but not all suggestion event types can be turned into an alarm, for example suggestion events for pattern matching.
We tried to create the following correlation rule to create a new alarm for :
  • filter: "Is Element Equal to DMA-65"
  • condition: "Is Source Equal to Suggestion Engine"
  • action: create new alarm with severity Critical
Running the correlation rules only shows alarms created by the suggestion engine, but no suggestion events (where source = suggestion engine as well).
Is there a way to also include suggestion events into the above correlation rule and exclude alarms which are coming from the suggestion engine?
correlation rule & suggestion events (ignored by correlation rule)
alarms created by suggestion engine (not ignored by correlation rule - but should be excluded)
Thomas Gunkel [SLC] [DevOps Enabler] Answered question 15th September 2021
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 14th September 2021 2 Comments
Hi Thomas,
You should include the severity into your 'Rule Condition'. This way you can make a distinction between the suggestion events and the alarms. It would look like this :
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 15th September 2021
Thomas Gunkel [SLC] [DevOps Enabler] commented 14th September 2021
Hi Michael. This excludes the unwanted alarm created by the suggestion engine, but still does not consider the suggestion events I am after.
By the way the severity of the alarms is not suggestion, but was a “warning high” and the severity of a suggestion even is “information”, could not find any suggestion severity.
Michaël Pincket [SLC] [DevOps Advocate] commented 15th September 2021
Hi Thomas,
As Veerle already indicated you can use the Severity ‘Information’ instead of ‘Suggestion’ and in your correlation rule you should turn on the option “Accepts information events”.
You are viewing 1 out of 5 answers, click here to view all answers.
