How to trigger a correlation that required a combination of several alarms ?
Solved1.82K views11th July 2023Correlation rules Deploying Solutions
Bernard Pichot [SLC] [DevOps Advocate]1.43K 19th December 2022 0 Comments
I need to execute a script when alarm A, B, C and not D are present
I know how to filter and group these alarms but is it possible in the correlation to indicate which alarms must be present simultenaously ?
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 19th January 2023 0 Comments
Hi Bernard,
Have you tried using the rule conditions to achieve this?
