How to support Flash Player for web interfaces?
Solved2.05K views6th July 2021web interface
Michiel Saelen [SLC] [DevOps Advocate]6.55K 1st July 2021 0 Comments
We have a set of devices that make use of Flash Player for the web interface.
After installing a package from the internet containing Flash Player for Chrome it did not make a difference.
As Flash Player is no longer supported by Adobe, but still used by some devices what is the easiest way to access the web interface for those devices?
Michiel Saelen [SLC] [DevOps Advocate] Selected answer as best 6th July 2021
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 6th July 2021 1 Comment
According to the Adobe Flash Player End of Life page on the Adobe website, the flash player no longer loads flash content from January 12, 2021. So even with the player installed, the pages will not load. I'm afraid there is no workaround available for this.
Michiel Saelen [SLC] [DevOps Advocate] commented 6th July 2021
Thanks for the response Michiel.
Indeed noticed the same, was hoping that there was a flash version that still is available that would.
