How to solve automation assembly warning?
Solved1.72K views3rd April 2024Automation
Mieke Dryepondt [SLC] [DevOps Advocate]4.24K 2nd April 2024 0 Comments
When I hit the validate button on my automation script I see the following warning:
Assuming assembly refernce 'mscorlib, Version=2.0.0.0n Culture=neutral, PublicKeyToken=b77a5c561934e089' used by 'System.Xml.Linq' matches identiy 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' of 'mscorlib', you may need to supply runtime policy
How do I resolve this?
I don't have it in Visual studio - DIS. and started to get it when adding the System.Xml.Linq nuget to my project.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 3rd April 2024
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 3rd April 2024 3 Comments
Hi Mieke
You don't need to use the NuGet for System.Xml.Linq. You need to use the assembly reference instead. Right click on the project and select 'Add Assembly Reference...'
There you can select the System.Xml.Linq assembly.
Mieke Dryepondt [SLC] [DevOps Advocate] Posted new comment 3rd April 2024
Mieke Dryepondt [SLC] [DevOps Advocate] commented 3rd April 2024
Thanks Michiel, that helped.
How do I know when to use a nuget and when to use assembly?
Should I add all System items as assembly? For example I have a similar problem after adding the System.IO.Compression nuget.
Michiel Oda [SLC] [DevOps Advocate] commented 3rd April 2024
All assemblies that are part of .NET Framework need to be added as Assembly Reference.
Unfortunately I don’t have a proper list (can’t find a proper list online either) but you can see which ones are available by going to the .NETFramework directory and see which ones are there (https://learn.microsoft.com/en-us/dotnet/standard/assembly/reference-assemblies#using-reference-assemblies).
Great info thank you Michiel!
