How to show elements snmp connection info (or https connection info ) in visio view ?
Solved1.25K views27th June 2025element connection info http connection info snmp connection info view
Dirk Van Herzeele14 10th September 2024 2 Comments
Hello,
Dataminer is not my core business so sorry if my question is a very basic one.
I know how  to link a shape to an element’s parameter in a visio view.
But How can I link a visio shape to the general  info you see in screenshot ?
Name,Description, Protocol can be linked with Parameter or info field I found but how can I show SNMP version and IPaddress/host in a view.
Some elements also have a https connection so same questioon but maybe similar to the SNMP info ; how can I show this in a view ?
I want to show an overview of all elements in a view because some elements make connection via DNS, others via fix IP address ….
More in general: is there somewhere a list of all possible info that can be retreived from an element (besides the elements specific parameters that can be seen in the protocols exported file ?)
I tried to search in the help menu but I haven’t found what I was looking for.
So if someone finds the time to give me a hint, that would be highly appreciated.
Thx already.
Best regards
Dirk
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.06K Posted 10th September 2024 2 Comments
Hi Dirk,
You could use the shape data ‘Info’ (Making a shape display information about the item it is linked to)
Hope it helps.
Dirk Van Herzeele commented 10th September 2024
I know about the INFO field and I already tested this but maybe I don’t know the correct syntax to retreive the snmp or http connection parameters . That’s why I asked if there is a sort of list with the syntax for all general info about an element…
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Hi Dirk,
On the following page, you can find a list of all the information about an element that can be displayed in a Visio drawing using keywords (under "To display information about the element to which the shape is linked"): https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/making_shapes_display_info/Making_a_shape_display_information_about_the_item_it_is_linked_to.html#configuring-the-shape-data-field
