How to share technical SRM booking info with a 3rd party?
Solved2.56K views11th July 2023SRM
Jochen Dewachter [SLC] [DevOps Member]2.17K 18th November 2020 0 Comments
When creating an SRM booking, a service is created in DataMiner with all the reserved resources. It has a nice visualization on top of it showing the entire signal path E2E together with technical info.
I'd like to share this overview with a 3rd party customer for which this booking was created in the first place. What are the options here? Does the 3rd party need a DataMiner account to access? Ideally it would be nice to just share a link from which they can monitor the booking.
FYI, the 3rd party doesn't necessarily have DataMiner knowledge.
Steven Soenens [SLC] [DevOps Member]444 Posted 19th November 2020 0 Comments
Perfect Jochen, I'll ask Reinout to sync with you as he is managing the roadmap for the UI developments. It's important we understand the initial expectations.
Steven Soenens [SLC] [DevOps Member] Answered question 19th November 2020
