How to set the correct filters when i am using ALARM ID as base parameter
Solved2.24K views17th October 2023
Marian Bacana155 30th May 2023 2 Comments
Hello,
I need some guidance. I am trying to set some filters on alarms so i can get something specific. Below is a capture from the filters window.
I am trying to use the Alarm ID to get exactly what i want.
So, on short, the id of the alarm i want to pick is 4653069. I tried to put this value on Filters column but the alarm does not disappears or appears. If i set the value of filter to *, and i place the ID of the alarm to the severity i want (eg. Critical Hi), i can get the alarm but there is also picking other alarms as well that do not have same ID.
I do not understand how the filter works in these cases. How can i set the alarm id so i can get the desired effect ?
Also, what should i write to the severity columns ? It only accepts a number... but what should i put in?
Thanks!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 17th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 4th July 2023
Hi Marian,
Has Randy’s comment helped you solve this? If not, could you add more information so we can help you further?
Marieke Goethals [SLC] [DevOps Catalyst] commented 17th October 2023
As this question has been inactive for a long time, we will now close it. If you want further assistance, could you post a new question?
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 30th May 2023 0 Comments
Hi Marian,
Since you are trying to alarm a specific row from a table, you will need to look for the display key column (it is the column that contains the suffix [IDX]). Normally the display key column is built based on values from other columns (values that are concatenated with a separator).
Most probably the alarm ID is included in the display key. Can you confirm if this is the case? If so, check where the alarm ID is located and try to build the filter based on this information.
For example, if the display key of the row is '4653069.MyAlarm', you could use as a filter 4653069.* (in this case the connector used the dot as separator)
Please also keep in mind that you should assign a severity to a column of that table that has a meaning for that alarm. Assign a severity to the column alarm ID does not provide meaningful information.
Hope it helps!
Miguel Obregon [SLC] [DevOps Catalyst] Edited answer 30th May 2023
