How to set column(s) via an Automation script
Solved3.64K views6th August 2020Automation script setcolumn setcolumns
Guilherme Gaspar [SLC] [DevOps Member]549 3rd August 2020 0 Comments
In a protocol, you can use the notify 220 to set column(s) on a table in one call.
Is there a similar way to do this in an Automation script? Or is the only option to use element.SetParameterByPrimaryKey() multiple times?
A workaround would be to adapt the driver to receive the command from the script and do the Setcolumns command via the protocol, but that's not desirable.
Marieke Goethals [SLC] [DevOps Catalyst] Edited question 6th August 2020
Davy Degrande [SLC] [DevOps Advocate]1.83K Posted 4th August 2020 1 Comment
The notify protocol 220 isn't available from an Automation script. However the notify protocol 336 NT_FILL_ARRAY_WITH_COLUMN_ONLY_UPDATES is available first argument needs to be an object[] 0. DMAID 1. EID 2. PID (table or column PID) and for the second argument the same data that would be passed on in a notify call from a QAction
Guilherme Gaspar [SLC] [DevOps Member] Selected answer as best 4th August 2020
Guilherme Gaspar [SLC] [DevOps Member] commented 4th August 2020
it works! Thanks
