How to set Bus Address from Automation script c#
Solved2.17K views18th July 2023automation scipt
Niraj Deval42 26th April 2021 2 Comments
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th April 2021
Hi Niraj, please could you elaborate a bit more your question? Are you planning to modify the bus address for an element?
Can you provide us more information about your use case?
Niraj Deval commented 26th April 2021
Yes, i would like to modify bus address for an element that is already created. bus address in TCP/IP settings
Miguel Obregon [SLC] [DevOps Catalyst]22.42K Posted 27th April 2021 0 Comments
Hi Niraj,
It will be interesting to know the use case that you are planning to cover with the automation script. Normally we use the bus address setting to point to a specific slot from a chassis. Changing the bus address will imply monitoring another card from the chassis using the same element (which is not recommended).
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 27th April 2021
