How to monitor online contacts (= active users)
Solved2.23K views5th July 2023account online users user activity user list
Nils Hoven [DevOps Advocate]1.82K 25th May 2023 1 Comment
We want to monitor if a specific user account is logged in to DataMiner / Cube. Manually, one can see which contacts (= user accounts) are currently logged in by checking the menu presented when clicking the current user's icon in the upper left corner. Is there any way to check this information in some kind of process, so we can work with this information? We have checked Information Events, but for some reason there are information events popping up related to user log in's / log off's even when the user is not actively changing it's status. So this does not seem to be a reliable source of information.
Thanks! 🙂
Alberto De Luca [DevOps Enabler] commented 25th May 2023
I believe we have a similar use case to submit – something where the active users can be checked via an “API” query perhaps, to know at a glance who are the users available at a given time (e.g. during an out of hours incident).
The system is keeping trace of user activity (System Center / Users / Activity), by keeping logs of the most recent sessions and the related actions in each of those (adding a screenshot later).
Alberto De Luca [DevOps Enabler]5.75K Posted 25th May 2023 0 Comments
Subscribing as I have a similar use case - I can refer to this kind of data in System center for the past sessions: wondering if there is a way to retrieve at least some of these stats (e.g. for the active sessions) via an API call?
Alberto De Luca [DevOps Enabler] Edited answer 25th May 2023
