How to mask alarms from a single interface?
Solved3.07K views11th July 2023
Jorge Sienra [SLC] [DevOps Member]375 10th January 2022 0 Comments
The idea is to be able to quickly mask and unmask alarms coming from one or more interfaces in a device, without having to mask the entire device.
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 11th January 2022 0 Comments
Hi Jorge,
Another approach is to use the filtering options with some wildcards in the alarm template to only alarm the production interfaces leaving the other ones without monitoring and the user can be able to work on those ones avoiding generating unnecessary alarms.
Operating that way, the user would need to rename the interface to force a mismatch with the alarm template filter and Dataminer will ignore that port until the label matches again.
Edson Alfaro [SLC] [DevOps Advocate] Answered question 11th January 2022
