How to mask alarms from a single interface?
Solved3.01K views11th July 2023
Jorge Sienra [SLC] [DevOps Member]375 10th January 2022 0 Comments
The idea is to be able to quickly mask and unmask alarms coming from one or more interfaces in a device, without having to mask the entire device.
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 11th January 2022 1 Comment
Hi Jorge,
In case you want to mask an interface (which is probably all cells from a row in a table?) before there is an alarm on it, I believe we don't have built-in support of this in DataMiner Cube for example, but we do have support for it in the back-end. We use it in DataMiner Cube in the context of EPM solutions.
Please checkout release note with internal ID20033 (Feature release 9.6.3 - Main release 10.0.0) as a starting point and maybe you do something with automation scripts?
Not sure if anyone else from the community already tried something similar?
Arturo Lizcano [SLC] [DevOps Member] commented 11th January 2022
I see the use case where a user needs to do some work in a particular interface and needs to mask it so it will not create any alarms.
The RN that you mention will allow us to do that? (with automation of course)
