How to make API call using Automation Script C#
Solved1.85K views18th July 2023API Automation script
Niraj Deval42 22nd April 2021 0 Comments
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 23rd April 2021 0 Comments
Hi Niraj,
There are various options, one of them is to use the HTTP Client class from the .net framework.
Please do note that the best way to interact with remote data sources is using a dataminer protocol and an element.
More information on how to set up HTTP communication in a protocol can be found in our development library here.
