How to integrate 3PP system/application with DataMiner using WebHook?
Solved29.08K views19th July 2023HTTP integration webhook
7
Mateusz Kalisiak10 13th January 2021 0 Comments
Hello,
I'm interested in integrating particular system with DataMiner using webhooks. Certain KPI information can be send from on of the systems to any destination (Datamiiner in this case) using webhooks. The thing is I'm not sure if and how DataMiner can be configured to listen for incoming HTTP(S) POST messages. I suppose, standard DataMiner's HTTP interface cannot be used here, because it is designed in a way that Dataminer initiates communication, i.e. sending HTTP request to source system. Here source system is going to post http messages in asynchronous way, like SNMP traps. Could you please advise how it can be implemented in Dataminer?
Regards,
Mateusz
Russ Wood0 Posted 18th May 2021 0 Comments
We are looking for a similar feature at Sky.
My colleague has created a feature request Here.
Russ Wood Answered question 18th May 2021
