How to increase the limit on incoming data for SLLog
Solved1.49K views18th January 2023log SLProtocol
Laurens Moutton [SLC] [DevOps Enabler]9.61K 17th January 2023 0 Comments
Since RN34801 on DataMiner 10.2.0[CU10] and 10.3.1 onwards, there is a limitation that a message in logging cannot be larger than 5 * 1024 characters.
I’m wondering if there is a way to increase this limitation somehow? This limit makes it harder to debug the communication with a device if the response is a larger json formatted string that is tried to be logged out by calling protocol.Log
Laurens Moutton [SLC] [DevOps Enabler] Selected answer as best 18th January 2023
Bert Buysschaert [SLC] [DevOps Advocate]5.07K Posted 18th January 2023 0 Comments
Hi Laurens,
At the moment this limit is hardcoded in SLLog and cannot be configured through settings. The goal was to limit the logging to reasonable chunks of data and avoid situations where a process tried to log hundreds of MB of data. Unfortunately for any limit we would have chosen a situation could occur where it would be useful to log just a little bit more.
