How to get current element IP address and show on page
Solved1.46K views27th January 2025
Muhammad Yousif Maher196 21st September 2024 0 Comments
How to get current element IP address and show on page?
Thanks,
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th January 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 21st September 2024 4 Comments
Hi Muhammad,
If you are referring to a page in an element, you can retrieve the IP address using a parameter of type pollingip (see DataMiner Docs)
If you are referring to a page in a visual overview (Visio file), you could use the data shape Info (see DataMiner Docs, ).
Hope it helps.
Muhammad Yousif Maher commented 24th September 2024
It was pollingip. Thank you!
QAction is not working on pollingip. Any workaround or am I missing something?
Miguel Obregon [SLC] [DevOps Catalyst] commented 24th September 2024
Hi Muhammad,
I believe you already this question in another post.
Please let me know if you have further questions
Thanks for your support. I got the answer. And it worked.
