How to find within DOM instance a particular section definition exists or not?
Solved1.54K views27th August 2024#automationscript #SectionDefinition DOM
Hari priya Venkatesan [DevOps Advocate]1.06K 31st May 2024 1 Comment
var domInstances= resourcemanagementHelper.DomInstances.ReadAll();
foreach (var domInstance in domInstances)
var abc= domInstance.Sections.Find(x=>x.SectionDefinitionID.Equals(Resourcemanagement.Sections.ResourceInternalProperties))
We are trying something like this but not able to figure out
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 27th August 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
Jens Vandewalle [SLC] [DevOps Advocate]10.09K Posted 3rd June 2024 0 Comments
Is it possible to verify if ResourceManagement.Sections.ResourceInternalProperties is of type SectionDefinitionID? If this is from the MediaOps solution, then you need to use Resourcemanagement.Sections.ResourceInternalProperties.Id to make it work.
I see that you are now retrieving all DOM Instances. In case you are only interested in the instances containing this section, you can use below code which will be more performant.
var filter = DomInstanceExposers.SectionDefinitionIds.Contains(Resourcemanagement.Sections.ResourceInternalProperties.Id.Id);
var instances = resourcemanagementHelper.DomInstances.Read(filter);
