How to find HOST Id of an element in Automation
Solved2.27K views11th July 2023host id hostId
hans sanders [DevOps Advocate]618 19th December 2022 0 Comments
I want to find out (in an automation script) what dataminer agent an element is hosted on.
In the past one could easily verify the DmaId using 'dummy.DmaId' but nowadays this method is no more 100% conclusive. Since elements can be migrated across agents the dmaid part in the full Element id is no longer a guaranteed reference to the hosting dataminer but only represents the agent the element was initially created on.
So my question is how to retrieve the actual 'host-id' of a given element...
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 19th December 2022 0 Comments
Hi Hans,
You can find the Hosting Agent ID by using: var hostingId = dummy.ElementInfo.HostingAgentID;
