How to distinguish service-level from element-level properties in AlarmEventMessage.Properties?
Solved916 views16th April 2026Ad Hoc data source alarm properties AlarmEventMessage low code app
Alexandre Bonnet [DevOps Advocate]10 16th April 2026 0 Comments
In a GQI ad hoc data source, I iterate over AlarmEventMessage.Properties to extract the value of a custom property named "PS ID".
This property is defined at both the service level and the element level. Both entries appear in the Properties array with the exact same Name ("PS ID") — there is no visible way to tell which entry comes from which source.
The only difference is in the value format:
- Service-level: single CFS or comma-separated (e.g. CFSXXXXXX,CFSXXXXXX)
- Element-level: slash-separated, listing all services of the element (e.g. CFSXXXXXX/CFSXXXXXX/CFSXXXXXX)
I currently work around this by skipping any property value that contains a "/" character, assuming it's the element-level entry. This works in practice but it relies on a format convention that isn't documented and could break silently.
I know that AlarmFilterField.PropertyValue uses typed prefixes ("service.PS ID", "element.PS ID") to distinguish sources when filtering alarms. But this only controls which alarms are returned — it doesn't help identify the source of each entry when iterating AlarmEventMessage.Properties.
My question: Is there a field on the individual property entries in AlarmEventMessage.Properties (e.g. Type, Source, or similar) that indicates whether the property comes from the service, element, view, or alarm level? Or is there an alternative message/API that returns properties with their source type clearly identified?
Thanks!
Debeuf Klaas [SLC] [DevOps Member] Answered question 16th April 2026
Debeuf Klaas [SLC] [DevOps Member]2.06K Posted 16th April 2026 1 Comment
Hi Alexandre,
You can use the DataType to make the distinction between the different property types.
Please let us know if this approach works for you.
Regards,
Debeuf Klaas [SLC] [DevOps Member] Edited answer 16th April 2026
Alexandre Bonnet commented 16th April 2026
Hi Klaas,
That's exactly what I needed, thank you!
Really appreciate the quick and clear answer!
Best regards,
Alexandre
