How to display uncancelled bookings by resource on Visio.
Solved1.11K views28th March 2025Resource Manager ResourceManager Visio
Takuto Kohara26 12th September 2024 2 Comments
I want to display uncancelled bookings for each resource one row at a time in Visio.
If I use "YaxisResources:Resource=R1,R2,R3", I can display each resource's bookings on a separate line, but it also displays cancelled bookings.
On the other hand, if I use "[sep::$]YAxisResources$[{"Type":"custom","Name":“NoCancelled","Background":"","Height":"*","FILTER":"ReservationInstance.Status != 7"}] ", all bookings except for cancelled bookings can be displayed, but the rows are not separated by resource.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Peter Vanpoucke [SLC] [DevOps Advocate]1.23K Posted 23rd September 2024 0 Comments
Hi Takuto
Out of the box it's currently not possible to achieve this, I believe. Here are a few suggestions to accomplish something similar, but each of them will show the canceled bookings on the timeline.
If the resources you want to display are part of fixed pools, you could use those to select the resources bands. There's an example here.
On the other hand you could consider the NoCancelled band, combined with the cancelled band (that has the inverted filter) as described here.
You could also consider the output of an Automation script. The viewport can be passed to the script to know what time is displayed. The script can output a variable holding a comma separated list of the resource IDs that need to be displayed. That variable can then be used to execute a set on the YAxisResources variable and to complete the "Resource=" filter. This is rather complex to implement though, and it might take a while to gather the resource IDs.
