How to display raw XML string in LCA component
Solved2.69K views15th April 2024grid component item template LCA string formatting
Jonas Kockx [SLC] [DevOps Member]287 15th April 2024 0 Comments
Hi
I noticed when trying to display a XML string in a grid component in LCA, that it is not displayed as the raw string.
E.g.:
New2604776177644032024/04/18 15:30:002024/04/18 16:00:002024/04/18 19:00:004a27bd2c-c010-409f-940b-3f512465c65d3 JPEG 2Kj2k150-PPNFL Atlanta Falcons vs. New Orleans SaintsSkyline Communications12906721280485150.5281MercedesBenzStadiumATLNFLMCRNY2024/04/13 05:10:12
Instead of:
<NMSHost><CircuitSetup><MessageType>New</MessageType><CircuitID>2604776</CircuitID><SharedID>17764403</SharedID><tLead>2024/04/18 15:30:00</tLead><tStart>2024/04/18 16:00:00</tStart><tEnd>2024/04/18 19:00:00</tEnd><ServiceType>4a27bd2c-c010-409f-940b-3f512465c65d</ServiceType><ServiceDescription>3 JPEG 2K</ServiceDescription><ServiceID>j2k150-PP</ServiceID><JobName>NFL Atlanta Falcons vs. New Orleans Saints</JobName><Client>Skyline Communications</Client><SequenceNumber>1290672</SequenceNumber><WorkOrder>1280485</WorkOrder><Capacity>150.528</Capacity><ProtectionID>1</ProtectionID><Source>MercedesBenzStadiumATL</Source><Path><Node>dtm11:1_LA-688-2</Node><Node>dtm2:8_LANim9</Node><Node>dtm6:1_TOR-688-1</Node><Node>dtm1:4_NYNim11</Node></Path><Destination>NFLMCRNY</Destination><TimeStamp>2024/04/15 08:23:42</TimeStamp></CircuitSetup></NMSHost>
How can I display the raw string in my grid component? (my string is a field of a DOM instance)
Jonas Kockx [SLC] [DevOps Member] Answered question 15th April 2024
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 15th April 2024 2 Comments
Hi Jonas,
Can you try replacing '<' with "&lt;", '>' with "&gt;" and '&' with "&amp;"? You may also want to wrap entire string in <pre> tag to maintain the formatting.
Let me know if this helps,
Cheers
Edib Šupić [SLC] [DevOps Enabler] Edited comment 15th April 2024
Jonas Kockx [SLC] [DevOps Member] commented 15th April 2024
Encoding my string by replacing the helped. I’ve created a custom GQI operator which encodes that column for me. Thanks! (the tag didn’t seem to do the job at first sight)
Edib Šupić [SLC] [DevOps Enabler] commented 15th April 2024
I’m happy to hear that. Did you encode < and > in the <pre> tag? If you did, can you try without encoding them just for the tag, in this case we want <pre> to be interpreted as an HTML tag.
