How to display raw XML string in LCA component
Solved2.90K views15th April 2024grid component item template LCA string formatting
Jonas Kockx [SLC] [DevOps Advocate]287 15th April 2024 0 Comments
Hi
I noticed when trying to display a XML string in a grid component in LCA, that it is not displayed as the raw string.
E.g.:
New2604776177644032024/04/18 15:30:002024/04/18 16:00:002024/04/18 19:00:004a27bd2c-c010-409f-940b-3f512465c65d3 JPEG 2Kj2k150-PPNFL Atlanta Falcons vs. New Orleans SaintsSkyline Communications12906721280485150.5281MercedesBenzStadiumATLNFLMCRNY2024/04/13 05:10:12
Instead of:
<NMSHost><CircuitSetup><MessageType>New</MessageType><CircuitID>2604776</CircuitID><SharedID>17764403</SharedID><tLead>2024/04/18 15:30:00</tLead><tStart>2024/04/18 16:00:00</tStart><tEnd>2024/04/18 19:00:00</tEnd><ServiceType>4a27bd2c-c010-409f-940b-3f512465c65d</ServiceType><ServiceDescription>3 JPEG 2K</ServiceDescription><ServiceID>j2k150-PP</ServiceID><JobName>NFL Atlanta Falcons vs. New Orleans Saints</JobName><Client>Skyline Communications</Client><SequenceNumber>1290672</SequenceNumber><WorkOrder>1280485</WorkOrder><Capacity>150.528</Capacity><ProtectionID>1</ProtectionID><Source>MercedesBenzStadiumATL</Source><Path><Node>dtm11:1_LA-688-2</Node><Node>dtm2:8_LANim9</Node><Node>dtm6:1_TOR-688-1</Node><Node>dtm1:4_NYNim11</Node></Path><Destination>NFLMCRNY</Destination><TimeStamp>2024/04/15 08:23:42</TimeStamp></CircuitSetup></NMSHost>
How can I display the raw string in my grid component? (my string is a field of a DOM instance)
Jonas Kockx [SLC] [DevOps Advocate] Answered question 15th April 2024
Seppe Dejonckheere [SLC] [DevOps Enabler]3.05K Posted 15th April 2024 1 Comment
Hi Jonas,
The grid component allows some html tags for markup purposes. It seems to me like the xml tags are being interpreted as html tags here, so they don't show up as raw text (and they probably don't show up in the DOM either, since those aren't valid html tags).
In order to show the raw xml string, you probably will have to html encode the string.
Jonas Kockx [SLC] [DevOps Advocate] Posted new comment 15th April 2024
Jonas Kockx [SLC] [DevOps Advocate] commented 15th April 2024
That was exactly the problem. I wrote a custom operator encoding my column by replacing some characters in my string as suggested in another answer. Thanks!
