How to create elements for Riedel & Calrec devices
Solved2.26K views7th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 7th March 2023 0 Comments
For the demo I used the Riedel and Calrec device drivers to create the elements, but I am getting timeouts.
The devices exist correctly.
Products include:
Riedel / RSP 1200
Riedel / Artist1024
Riedel / Artist System Info (provided by TV2 Norway)
Calrec / Artemis
The drivers used are as follows
These do not seem to be accompanied by a Help page.
Riedel_Communications_Artist_128
Riedel_Communications_Artist_SNMP
Riedel_Communications_RSP_1200
Calrec_Artemis
I would like to know how to use each driver.
Thomas Gunkel [SLC] [DevOps Enabler]1.23K Posted 24th March 2023 1 Comment
Hi Yuki,
which Riedel APP are you running on the RSP1200 panel? Do you want to use it a intercom panel or panel to remote-control DataMiner with it?
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] Posted new comment 28th March 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 28th March 2023
Unfortunately I did not know what it meant.
Do you mean that I need another software to monitor with Dataminer?
