How to create elements for Riedel & Calrec devices
Solved2.19K views7th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]919 7th March 2023 0 Comments
For the demo I used the Riedel and Calrec device drivers to create the elements, but I am getting timeouts.
The devices exist correctly.
Products include:
Riedel / RSP 1200
Riedel / Artist1024
Riedel / Artist System Info (provided by TV2 Norway)
Calrec / Artemis
The drivers used are as follows
These do not seem to be accompanied by a Help page.
Riedel_Communications_Artist_128
Riedel_Communications_Artist_SNMP
Riedel_Communications_RSP_1200
Calrec_Artemis
I would like to know how to use each driver.
Stacey Van Colen [SLC] [DevOps Member]2.67K Posted 7th March 2023 1 Comment
Hi Yuki,
On the Driver catalog you are able to search for the available drivers, and there you should also find the help file. In the help there should be a section on 'Installation and Configuration'. This should provide you with the details you are looking for.
Here you can find the links to the catalog for the drivers you listed:
  • Riedel_Communications_Artist_128 : https://catalog.dataminer.services/result/driver/1825
  • Riedel_Communications_Artist_SNMP: https://catalog.dataminer.services/result/driver/7435
  • Riedel_Communications_RSP_1200: https://catalog.dataminer.services/result/driver/6248 (no help page available)
  • Calrec_Artemis: https://catalog.dataminer.services/result/driver/6963 (no help page available)
For the two drivers without a driver help, we'll have to see if anybody else in the community already has experience with them.
Kind regards,
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] Posted new comment 7th March 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 7th March 2023
Unfortunately none of the drivers worked.
It is my belief that we have obtained a driver that we cannot possibly monitor.
When I do a port scan on the device, there is a difference from the default port number specified in the driver.
For example, RIEDEL is not Listen for 161, 8193, and 8194.
