How to create an AlarmFilter for alarm properties?
Solved3.21K views20th April 2023alarmFilter alarmrepository alarms SendSLNetMessage
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K 19th April 2023 0 Comments
Hello,
I'm trying to get the history alarms based on a time range and a property value. I created the following AlarmFilter but it doesn't seem to be working:
var alarmFilterByProperty = new AlarmFilterItemString(AlarmFilterField.PropertyValue, propertyName, AlarmFilterCompareType.Equality, new[] { propertyValue });
var alarmFilter = new AlarmFilter { FilterItems = new AlarmFilterItem[] { alarmFilterByProperty, }, };
Is there something that I'm missing in the filter? Or may the problem be in the SLNetMessage (I'm using GetAlarmDetailsFromDbMessage instead of the AlarmRepository)?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 20th April 2023
Debeuf Klaas [SLC] [DevOps Member]1.94K Posted 20th April 2023 0 Comments
Hi Sebastian,
Maybe indeed it's the GetAlarmDetailsFromDbMessage , can you share me the full script or context?
Debeuf Klaas [SLC] [DevOps Member] Answered question 20th April 2023
