How to correctly implement responses on a connector using multiple smart-serial Connections?
Solved2.08K views25th October 2021connections smart-serial
Diogo Silva [SLC] [DevOps Member]214 25th October 2021 0 Comments
Considering a connector that has multiple smart-serial connections.
If we implement a response without any specific options="Connection:x" field, what is the expected behavior?
Will this response by default get only responses from the main connection (id = 0), or will it be able to retrieve responses from any of the configured connection as well?
Diogo Silva [SLC] [DevOps Member] Selected answer as best 25th October 2021
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K Posted 25th October 2021 0 Comments
Although it is not exactly the same setup, this article might already provide you some good insights on best practices:
How to define serial and smart-serial responses in one and the same driver - DataMiner Dojo
The "How to" clearly states to always add the connection Id. I would suggest you do the same when working with multiple smart-serial connections. This way you are sure how everything will behave.
