How to connect to a Cisco Nexus switch?
Solved2.98K views7th July 2021Cisco Nexus
Thomas Gunkel [SLC] [DevOps Enabler]1.24K 12th August 2020 0 Comments
The DataMiner Cisco Nexus driver seems to support HTTP and SNMP polling. Should both methods be used in parallel to benefit from all DataMiner Nexus driver features or is one method preferred?
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 7th July 2021
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 26th August 2020 0 Comments
The CISCO Nexus uses different polling types to retrieve information:
  • SSH: NBM interfaces
  • HTTP: PTP information
  • SNMP: all other information available in the protocol
More information about this protocol can be found in the catalog.
Note that this also depends on the version range you have installed on your system.
