How to configure Cisco Switch to interface with DataMiner
Solved1.34K views22nd April 2025Cisco Manager
Miguel Barquet [SLC] [DevOps Advocate]1.92K 5th November 2024 0 Comments
A customer asked for help configuring their lab Cisco switch to monitor in DataMiner. I am going to use the Cisco Manager connector. I’d appreciate it if someone could share the configuration that needs to be applied to the switch. The documentation indicates CISCO Manager | DataMiner Docs uses SNMP and HTTP connections, we can also see that in the element settings, however I haven’t yet found guidance on how to configure the switch.
Thanks in advance your guidance.
Miguel Barquet [SLC] [DevOps Advocate] Selected answer as best 22nd April 2025
Euler Peron [DevOps Member]107 Posted 6th November 2024 0 Comments
Hi MIguel.
first, you got to configure your Cisco Switch adding snmp sections and set communities correctly, second, choosing and enabling the trap groups on the switch configuration and the access list adding the dataminer host to the authorized access for the snmp ports choosen.
After that, you put the communities, port and ip address of the switch on the element configuration and start it.
Then you just got to choose what you want on the pooling configuration.
look at this for the switch config:
SNMP Configuration Guide – Configuring SNMP Support [Cisco ASR 1000 Series Aggregation Services Routers] – Cisco
Regard
