How to configure Arista switches to establish communication with DataMIner?
Solved3.45K views23rd January 2023
7
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 19th January 2023 0 Comments
Are there guidelines available how to pre-configure an Arista switch and which minimum privilege level is required, so that our DataMiner connector can retrieve and set all parameters? Our connector uses a mix of protocols, e.g. SNMP, eAPI, syslog etc...
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 23rd January 2023
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 19th January 2023 0 Comments
Hi Thomas,
Please find below the most important CLI commands that can be used on Arista eOS switches to allow dataminer to communicate.
You'll need to make sure the management interface has a valid ip address.
interface management1
ip address 192.168.1.20/24
(note that a default gateway might also need to be defined).
You need to enable the HTTPS management
management api http-commands
protocol https
no shutdown
You need to set a SNMP community string
snmp-server community public
You need to define a username / password
username myuser secret 0 mypass
Finally you'll need to make sure your changes are saved to the startup config
copy running-config startup-config
  • Important note: the user created using the sample commands above will have privilege level 1, mare sure this is compliant with your company security policy.
