How to configure Arista switches to establish communication with DataMIner?
Solved3.50K views23rd January 2023
7
Thomas Gunkel [SLC] [DevOps Enabler]1.24K 19th January 2023 0 Comments
Are there guidelines available how to pre-configure an Arista switch and which minimum privilege level is required, so that our DataMiner connector can retrieve and set all parameters? Our connector uses a mix of protocols, e.g. SNMP, eAPI, syslog etc...
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 23rd January 2023
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 19th January 2023 0 Comments
Hi Thomas,
Our help currently doesn't have a set of commands/features that need to be enabled on the switch to establish all required communication. The connector will indeed mainly require that SNMP and eAPI communication is enabled.
Note that some functionality, for example setting up receival of sflow, can be configured in the element itself once basic communication has been established.
I did take note of this so we can further improve our documentation.
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 19th January 2023
