How to check if an Element is Masked?
Solved1.22K views19th March 2025class library IDmsElement mask
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 19th March 2025 0 Comments
Through an Automation Script, I would like to check if an element is masked or not.
I thought I had to use the IDmsElement State property to do so, but this returns Active.
What do I need to use to check if an element is Masked?
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 19th March 2025
Ive Herreman [SLC] [DevOps Enabler]14.77K Posted 19th March 2025 0 Comments
Hi Mieke,
You can read parameter id 65008 (which is visualised on the general parameters page).
