How to Check Cost Beared by the AWS after Connecting with DataMiner
Solved766 views9th September 2025AWS AWS CloudWatch Cost
FAWZAN KHAIZURAN FAUDZI [DevOps Advocate]234 28th February 2025 0 Comments
Hi all,
How can we check the additional cost to beared by AWS (i.e AWS Cloudwatch) after we connect it to the DataMiner?
I am using an AWS CloudWatch Connector to connect it DataMiner and currently trying to check the cost via Billing and Cost Management Page from AWS (as shown below) but not sure which parameter to choose.
Thank you very much for your assistance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 9th September 2025
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.05K Posted 11th July 2025 0 Comments
Hope you've found an answer in the meantime since you posted this.
I took a cursory look at the connector and see that it is making several API calls amongst which GetMetricData and ListMetrics have potential costs associated with them.  Configuration options are also provided to really control the frequency of these calls.
To your question itself I think perhaps that it might be better suited in an AWS forum where you can get more detailed information on how to navigate the Billing interface.
Feel free to circle back here with your solution. It will be appreciated.
