How to Back Up and Restore a DaaS System in Case of Decommissioning?
Solved2.65K views16th December 2024backup DaaS
KinetiMinds Tech [DevOps Advocate]272 12th December 2024 0 Comments
I’d like to know the best way to back up my DaaS system to ensure I can restore it later if my DataMiner credit expires and the system gets decommissioned. Are there any specific tools or processes I should follow to make this seamless?
KinetiMinds Tech [DevOps Advocate] Selected answer as best 16th December 2024
Debeuf Klaas [SLC] [DevOps Member]1.89K Posted 16th December 2024 0 Comments
I’m afraid that we don’t support this full system backup at the moment for decommissioned DaaS systems.
The VM Backups are also removed when the system is fully decommissioned(after 10 days).
Regards,
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 12th December 2024 1 Comment
Hi
we are taking backups of all systems to provide options for restore in case something goes wrong or the system is decommissioned. If you want to get access to such a backup you can always contact support and they will be able to provide one to you.
Note that the docs are currently not entirely correct and we will update them with this information.
Hope this helps you!
With kind regards.
Thomas Verschuere [SLC] [DevOps Member] Posted new comment 12th December 2024
Thomas Verschuere [SLC] [DevOps Member] commented 12th December 2024
Hi
The backup does does get deleted 10 days after the system is decommissioned. We only take backups from running systems.
José Silva [SLC] [DevOps Enabler]2.10K Posted 12th December 2024 0 Comments
Hi KinetiMinds,
The DataMiner System will still be recoverable for a further 7 days after the expiration or deletion. To recover the system, contact daas@dataminer.services.
More information here: Frequently asked questions related to DaaS | DataMiner Docs
José Silva [SLC] [DevOps Enabler] Answered question 12th December 2024
Debeuf Klaas [SLC] [DevOps Member]1.89K Posted 12th December 2024 1 Comment
Hi KinetiMinds,
You can order extra credits to keep your system alive, see Order DataMiner Credits.
If you need to take a backup of your elements or services only, you can use Exporting and Importing.
Regards,
KinetiMinds Tech [DevOps Advocate] Posted new comment 12th December 2024
KinetiMinds Tech [DevOps Advocate] commented 12th December 2024
Dear Debeuf,
Thanks for your response.
I understand the option to order extra credits, but my concern is about preparing for a scenario where my current DaaS system gets decommissioned. In such a case, I need a full system backup—not just the elements and services, but also the users, protocols, configurations, and any other system-wide settings.
Could you please advise if there’s a way to perform a comprehensive backup that would allow me to fully restore my system to a new DaaS instance in the future?
