How modify SNMP settings, timeout value of an element via automation script ?
Solved522 views6th November 2025
Sok-Khing Ta46 1st September 2025 0 Comments
Hello,
via automation script, how to modify SNMP settings, timeout value of an element ?
Fenta Alemahu [SLC] [DevOps Advocate]1.34K Posted 1st September 2025 0 Comments
Hi Sok-Khing
You can achieve this in a couple of steps by exploiting the IDms interface:
  • Retrieve the IDms interface in the Automation engine: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Automation.EngineExtensions.GetDms.html
  • Using the IDms interface, get the element you want to manipulate: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Common.IDms.GetElement.html
  • Retrieve the element properties that you would like to modify: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Common.IDmsElement.html
    1. You can get the element timeout setting from the AdvancedSettings property: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Common.IAdvancedSettings.Timeout.html#Skyline_DataMiner_Core_DataMinerSystem_Common_IAdvancedSettings_Timeout
    2. You can get the SNMP settings by first getting the Connections property of the element and then casting that to one of the SNMP type connection itnerfaces. https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Common.IDmsElement.Connections.html#Skyline_DataMiner_Core_DataMinerSystem_Common_IDmsElement_Connections
