How many retries are made when the connection to the DB is lost while DataMiner is running?
Solved1.09K views30th April 2024Cassandra cassandra cluster
Christine Kapembe [SLC] [DevOps Advocate]1.01K 18th December 2023 0 Comments
According to DB.xml | DataMiner Docs, one can set the number of retries to connect to Cassandra DB during DataMiner startup. How many retries are made when the connection to the Cassandra DB is lost while DataMiner is running? Can this setting be configured as well?
What happens when the network connection is restored after the number of retries have been exhausted? Is there a way to re-establish the connection to the DB without restarting DataMiner?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th April 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.24K Posted 30th April 2024 0 Comments
As this question has now been open for a long time without any activity, we will now close it. If you do still want more information, could you add a new question, possibly focusing on more specific items?
