How long is RequestLoginAsTicket Valid?
Solved1.10K views12th July 2023
Dang-Khoa NGUYEN70 5th October 2022 0 Comments
Hi.
we use the following process to connect DMA GW Dashboard:
1/  call API DMA ConnectAPP: parameter (login/passwd) result (Connection Id)
2/ Call API DMA RequestLoginAsTicket parameter (Connection Id) result (RequestLoginAsTicketResult)
3/ https://[DMAIP]/dashboard/#/?ticket=[RequestLoginAsTicketResult]
Can you advise about:
The duration of validity of RequestLoginAsTicketResult ?
How the validity duration can be configured?
Thank You.
BR.
Gellynck Jens [SLC]2.72K Posted 5th October 2022 0 Comments
The ticket validity (measured in seconds) is configurable by the <TicketExpirationTime> in the <SLNet> of the MaintenanceSettings.xml (located in C:\Skyline DataMiner).
<SLNet>
<TicketExpirationTime>300</TicketExpirationTime>
</SLNet>
The config above will ensure tickets are valid for 300 seconds (5min). Tickets do not persist across DataMiner restarts, meaning if the DataMiner restarts all issued tickets become invalid.
