How long is a connection string valid when requesting one through Soap calls?
Solved2.35K views30th June 2020API communication SOAP
Michiel Saelen [SLC] [DevOps Advocate]6.55K 30th June 2020 0 Comments
How long is connection string valid that is requested through the soap/API calls?
Is there a possibility to change this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th June 2020
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 30th June 2020 0 Comments
Whenever a web method gets called using that connection string, then its expiration gets extended with 5 minutes. So it could stay valid for a very long time (if recycling in IIS is disabled).
If the connection string hasn't been used for 5 minutes, then it won't be valid anymore. But then you can just request a new connection string by authenticating again. This way it's not taking up server resources which aren't used for such a long time.
The 5 minutes interval is hardcoded and is not configurable.
