How enable dashboard settings
Solved1.16K views4th June 2024
Nicolás Raul Bonina66 18th March 2024 0 Comments
<span class="Y2IQFc" lang="en">How do I enable the configurations for the dashboards. I don't see the panels.</span> Depend of the user? I attached Ty very much<img src="https://community.dataminer.services/wp-content/uploads/anspress-temp/af27793efdd770571184f4dbe601d80314ca9daa_7959.png" />
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th June 2024
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 18th March 2024 0 Comments
Hi Nicolás,
There are two levels of security that impact the dashboards.
First, you need to have the "Add" and "Edit" rights for dashboards. These can be configured from the user & groups section in the DataMiner Cube System Center.
Secondly, per dashboard there is a user access section in the settings, where you can configure which users are allowed to view and edit a specific dashboard.
