How does a string parameter store binary data?
1.06K views11th June 2026XML
Khoo Chee Yang [SLC] [DevOps Advocate]342 11th June 2026 2 Comments
I have a device that sends binary data. This binary data populates a read parameter of rawtype (other) and type (string). Does dataminer convert the binary data into an ascii string or does it leave it alone?
Laurens Moutton [SLC] [DevOps Enabler] Answered question 11th June 2026
Laurens Moutton [SLC] [DevOps Enabler] commented 11th June 2026
Through what connector connection type is the binary data received? Is it through SNMP connection (e.g. octetstring type), or through an HTTP connection type, websocket, (smart)-serial connection?
Khoo Chee Yang [SLC] [DevOps Advocate] commented 11th June 2026
Hi Laurens!
It is through serial connection
Laurens Moutton [SLC] [DevOps Enabler]9.97K Posted 11th June 2026 0 Comments
Data entering from a serial response stores the raw bytes into the parameter without modifying them.
The way these bytes are displayed back depends e.g. if the unicode option is active or not as it will try to interpret these bytes as text characters depending on the used code page.
If a protocol.GetParameter() is called, there has already been conversion applied to the returned result as it expects it to be a string. Converting back the raw bytes based on that string could mean that some bytes are not as expected anymore.
Getting the raw bytes in a QAction as they were received in the response can be done by calling protocol.GetData as documented here
Regards,
