How does a string parameter store binary data?
1.07K views11th June 2026XML
Khoo Chee Yang [SLC] [DevOps Advocate]342 11th June 2026 2 Comments
I have a device that sends binary data. This binary data populates a read parameter of rawtype (other) and type (string). Does dataminer convert the binary data into an ascii string or does it leave it alone?
Laurens Moutton [SLC] [DevOps Enabler] Answered question 11th June 2026
Laurens Moutton [SLC] [DevOps Enabler] commented 11th June 2026
Through what connector connection type is the binary data received? Is it through SNMP connection (e.g. octetstring type), or through an HTTP connection type, websocket, (smart)-serial connection?
Khoo Chee Yang [SLC] [DevOps Advocate] commented 11th June 2026
Hi Laurens!
It is through serial connection
Maria Correa [SLC] [DevOps Advocate]263 Posted 11th June 2026 0 Comments
Hello!
I believe it leaves it alone.
According to the Dataminer ECS XML agent on copilot CLI:
With rawtype="other" + type="string", DataMiner treats the value as an opaque byte sequence. It does not interpret, transcode, or null-terminate the data. What the device sends is what gets stored in the parameter.
If you need to process the binary data, you'd typically trigger a QAction on that parameter and handle the conversion yourself using protocol.GetParameter(), which returns it as a string (byte array marshalled as a .NET string).
Maria Correa [SLC] [DevOps Advocate] Answered question 11th June 2026
