How do I display of an Element status in a view?
Solved1.85K views19th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 8th March 2021 0 Comments
I want to be able to view the status of Element outages in a View without alarm template.
Is there any way to identify manually stopped elements?
A syntax that returns Active/Stop/Pause is desirable.
That distinguishes it from device problems such as timeouts.
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 8th March 2021 1 Comment
Hi Yuki,
Another option for this case could be using listView. For example, if you would like to display the active elements for the view 'MyView', you could define the following data shape in a shape:
This will result in the following overview:
You can find more information about how to use listView shape data in DataMiner Help - ListView.
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 9th March 2021
ListView is close to what I’m looking for.
I only want the STATE in this one.
