How do I display of an Element status in a view?
Solved1.86K views19th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 8th March 2021 0 Comments
I want to be able to view the status of Element outages in a View without alarm template.
Is there any way to identify manually stopped elements?
A syntax that returns Active/Stop/Pause is desirable.
That distinguishes it from device problems such as timeouts.
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 8th March 2021 1 Comment
Dear Yuki Arakawa,
If you would like to show stopped or paused elements under a view, you can use the following Shape Data on your Child group:
ChildrenFilter: AlarmSeverity:Undefined
Normally, the following Alarm severities can be used in this syntax:
  • Undefined
  • Normal
  • Warning
  • Minor
  • Major
  • Critical
  • Information
  • Initial
  • Masked
  • Error
  • Notice
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] Posted new comment 9th March 2021
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 9th March 2021
Wouldn’t this all be undefined without the use of an alarm?
