how can we configure Arista cloud vision using connectors in dataminer catalog?
Solved970 views27th June 2025Arista
Raghav Nanda44 25th March 2025 0 Comments
I was curious if there was any way to bypass configuring each arista device and configure arista cloud vision instead using connectors provided in the dataminer catalog. Or the solution is to make a custom connector for achieving the same.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 4th April 2025 0 Comments
Hi Raghav,
Currently, there is no Arista CloudVision connector available in the DataMiner catalog. However, you have a few options going forward:
  1. Use the Arista Manager connector to monitor individual switches directly.
  2. Request the development of a new connector via your Skyline Sales representative.
  3. Develop a custom connector yourself, if you have the resources and expertise in-house.
