How can I implement Signalr in a protocol solution?
Solved2.85K views11th July 2023Signalr
Julian Yepe [SLC] [DevOps Member]316 26th October 2022 0 Comments
I would like to know if it is possible to implement Microsofts Signalr library in a protocol solution. Signalr is a .NET library that allows for real-time updates from the server to the client and is made for ASP.NET (more information here). I am able to download the NuGet packages required, but I run into an issue where I am getting a 'TargetInvocationException' when running the code. I am not sure if this exception is happening because Signalr is meant for the ASP.NET framework or because there is a reference that I might not be aware of. Any help is appreciated. I have added a screenshot for reference.
Here is the exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeLoadException: Method 'DisposeAsync' in type 'Microsoft.AspNetCore.SignalR.Client.HubConnection' from assembly 'Microsoft.AspNetCore.SignalR.Client.Core, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' does not have an implementation.
at QAction.Run(SLProtocol protocol)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
at CManagedScript.Run(CManagedScript* , Int32 iDmaId, Int32 iEid, Int32 trigger, Int32 iCookie, IUnknown* pILog, IUnknown* pProtocol, tagVARIANT* varParameters, tagVARIANT* varRowInfo, tagVARIANT* pvarReturn)
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 7th December 2022 0 Comments
Hi Julian,
which version are you using of the NuGet?
Internal testing pointed out that some versions gave exceptions, but no further investigation happened. If this implementation is important i would indeed chase this further with internal experts.
Marlies Vandenberghe [SLC] [DevOps Member] Answered question 7th December 2022
